Beautiful work color catches my eye I fight to stay intall with my trucks progress...I come here for inspiration to kick me in the arse...keep me in the right direction
BobbyFord wrote: ↑Fri Aug 16, 2024 6:46 pm
I should also post upgrade pics of the disc brake install.
I was never happy with the brake pedal after the disc brake conversion (link in the first post of this thread.) I used aftermarket booster and master and never liked it. I wound up using OEM booster and master available at any local parts store.
72 F100 firewall booster brackets
Cardone booster # 54-73515
Napa master cylinder for 75 disc F100
P2 disc/drum combo valve from Summit Racing
Bobby, did you make the P2 Combo Valve bracket? I really like how that looks!
It was this bracket > https://www.summitracing.com/parts/aaf-all41045
Turned out it was too close to the master cylinder and I had to add metal to space it farther down. I could have just mounted the valve under the bracket but it just looked better on top of the bracket.
