Back to the shop update #2
marz68
Post by marz68 »
showfest is going to rock!
The IF crew was supposed to leave tuesday at 6pm but ended up leaving at midnight, it was a long day trying to get to customer trucks done before they could leave.
Hey layedout my grill is still stock looking right now but it's funny that I don't have any shot's of the fron't grill like if I was trying to hide something. :evil:
marz68
Post by marz68 »
Here are some pics of the work I did this weekend.
marz68
Post by marz68 »
Alway's remember what section you just finished welding
cause you can get burned really nasty. :cry:
customcrewcab
re: Back to the shop update
Post by customcrewcab »
kindof interested in what your going to do for inner fenders. i have acouple ideas but not sure what would look the best.
marz68
Post by marz68 »
Last pics.
layedout72
Post by layedout72 »
it looks amazing marz, but can u explain the body mount situation, how u line them up and all? because thats where im lost. i know you went from a 6 inch tall frame, to a 3 inch tall frame. how did u drop the mounts and all? My buddy was trying to explain it, but we were all drunk and well...i dont remember lmao.
if u dont mind of course.
marz68
Post by marz68 »
Thank's layedout.
I think it's harder to explain it than it is to do it but here I go.
You will have to measure your stock frame to get the with and the distance from the front to rear mount's, then to get the height what I did was to tack 2 square bars under the frame,these bars will support the weight of the cab so that the bottom of the cab can sit level with the bottom of the frame wich means that if you lay out your frame you will also be laying out your doors :twisted:.
After that was done I made a cardboard template of the mount and trnsferd it to a 1/4" plate, remember to take into consideration the thickness of the rubber mount plus I gave it 3/8 more to have some adjustment if I need it cause it's essayer to shim the mount than it is to cut a weld it again.
Hope this makes cense :hmm:
layedout72
actually, that makes sense. its like a traditional really, that u want the body even with the stock frame, just your doing new mounts.
stockr
Post by stockr »
looking foward to seeing finished...so far i like it alot....
99 COBRA-DAILY DRIVER
95 F150 EDDIE BAUER-BAGGED
94 BRONCO EDDIE BAUER-FISHN TRUCK
71 F100 SWB- HAS BEEN POSTPONED
grounded72
Post by grounded72 »
keep up the good work man
..................................... ___
..................._________|___\____
..;.;;.:;:;.,;.|__(O)____|____/_(O)|
