Miles per gallon for a 2bbl 360
Darren
Re: Miles per gallon for a 2bbl 360
Post by Darren »
I get 18.5 mixed city and hwy. with a 360 2v tree speed and 3.0 rear end.
"Do it now, or wish forever that you had."
hotrodfeguy
Post by hotrodfeguy »
My 352 4X4 10-12MPG
My 390 4X4 10-12MPG
1972 F-250 4X4 390
1999 F-350 7.3 PS 4X4
1996 Ford ranger 3.0
1969FordMan
Post by 1969FordMan »
I get about 10, I get better putting along at 55mph, I get 11-12, Loaded with 2600 lbs at 70mph every time I look down the gauge has moved. Drove 100 miles (in town mixed with hiway) on a little on little over half a tank. Staring and stopping in town sucks fuel mercilessly. I measure in blocks per gallon then LOL.
1969 F100. All factory 360, 4-speed, candy apple red one owner. Incredible truck!
ToughOldFord
Post by ToughOldFord »
John Lamber wrote:Between 7 and 8 MPG with a F250 CS 360 2bbl and automatic transmission.
That's what I got when I had that same setup. It went up to nine when I upgraded to a manual transmission.
DragRag
Post by DragRag »
72' F100 360cid, 3.00 gears, 63k original miles, runs perfect. I have a 4 speed trans, tires set at 35psi all the way around. On my trip from Salem Oregon to Hollister Ca, I filled up 4 time between 10 and 15 gallons. I calculated my second fill up at 14.08 mpg, and my third fill up on more flat terrain at 14.5 mpg exactly. I was averaging between 65 and 75 mph highway driving only. I think if I took it down to 55-60 mph I could do better. These are honest numbers, and I gave you my gear ratio. I think it has a lot to do with it, plus I am not running a slush box trans, that helps to.
