72 F100 project, longbed to short conv, CV swap, 20s
68bumps
Re: 72 F100 project, long bed to short bed conversion (+CV Swap)
Post by 68bumps »
JG F100 wrote:I've been chipping away on the CV swap little by little....
I made some brackets for the trailing arms.
[ Image ]
[ Image ]
Boxed in the frame...
[ Image ]
[ Image ]
[ Image ]
Brushed on some POR15...
[ Image ]
[ Image ]
[ Image ]
Put in down on all fours again... and yes those are ET streets on the front from my other car. I've been wheel shopping but I need to get
the sheetmetal back on to see how much offset is required. Thinking of 20s all around or maybe a 22/20 combo
[ Image ]
[ Image ]
[ Image ]
In this picture (http://i545.photobucket.com/albums/hh38 ... 5-1606.jpg) is the back surface of your steel bracket contacting the frame and then braced up the side? Or is it spaced away from the frame and then braced?
Also, I love how you shorted the frame and bed to make it a swb. Kudos to your craftsmanship.
JG F100
Post by JG F100 »
68bumps wrote: In this picture (http://i545.photobucket.com/albums/hh38 ... 5-1606.jpg) is the back surface of your steel bracket contacting the frame and then braced up the side? Or is it spaced away from the frame and then braced?
Just the rear portion is touching/welded onto the frame. I remember tack welding them in first then added some bracing.
milkman27
Re: 72 F100 project, longbed to short conv, CV swap, 20s
Post by milkman27 »
Hey, I love your truck and what you have done to it!!! what back spacing did you use on the back wheels?
diznasty
Post by diznasty »
Love your truck man. What brake booster/MC did you use? I just picked up a cv front end fully loaded for $100. The guy is letting me take anything I want, minus the frame, so I was going to grab the brake booster/mc.
JG F100
Post by JG F100 »
On the back the bs is 3.75" on a 10" wide rim.
diznasty wrote:Love your truck man. What brake booster/MC did you use? I just picked up a cv front end fully loaded for $100. The guy is letting me take anything I want, minus the frame, so I was going to grab the brake booster/mc.
I used a GM astro van hydroboost with a C3 vette master cylinder.
thanks
jetdrive
Post by jetdrive »
hey guys i am wondering if any one out there could help me .i am just getting ready put a 4.6 dohc motor in my 66 f100 cv front end swap .its computer time ,any ideas on the wireing.the motor and trans is out of a 94 mark 8 and i have the harness and computer.any hepl would be great
RCF100
Post by RCF100 »
My crown vic setup is almost complete but I got a power steering leak. My truck came with power steering do I need to change the pump to the crown vic one?
72 F100 XLT ranger 390
elgemcdlf
Post by elgemcdlf »
RCF100 wrote:My crown vic setup is almost complete but I got a power steering leak. My truck came with power steering do I need to change the pump to the crown vic one?
You do not need to change to the CV pump. Locate your leak & fix. All will be good then.
69timemachine
Post by 69timemachine »
I just read your entire thread and I have to say you've done a great job on your truck! If I hadn't already promised myself that I would never cut on my current bump, I'd already be looking for a Vic to strip! Oh well, if I ever build another bump or a dent, I'll know exactly what needs to be done now! Keep up the great work! :thup:
Jason
"Where there's a wheel, there's a way!"
'69 F100 SWB in Lunar Green with built 351C & TKO-600 5-speed, 4.56 gears, and Eaton TrueTrac Posi.
Future plans: Maybe one day, fresh paint, though I've been told by some, "Don't touch it! It's done!"
'06 Mustang GT 5-speed
Sold: '77 F100, '72 Gran Torino, '76 El Camino with 454 & TH400
69timemachine
One question I recently thought of; what suspension do the Lincoln Town Cars have under them? Is it the same as the Crown Vic? If so, that could be another resource for parts. And the Town Cars have air ride, don't they? :dk:
Jason
rusty63
Post by rusty63 »
Yes & I think so…
jsteven22
Post by jsteven22 »
The stance and wheel combo is awsome!!!! Do you have a problem with the front wheels scrubing when you turn them?
Bryanc81
Post by Bryanc81 »
Nice work! I have a 73 long bed and want to do the same thing to it. We have had the truck for about 15 years now and it's just been sitting rotting away. Hope to start on it soon.
SkinnyPedal
Post by SkinnyPedal »
Great Work. 8) We are doing a 77 dent side. Watching.
One of the advantages of being disorderly is that one is constantly making exciting discoveries.
48prerunner
Post by 48prerunner »
JG F100 wrote:Got the parking brake working, feels good to not have to grab a block of wood to keep it from rolling down the driveway. I used one of the OEM explorer cables for the passenger side and bought a longer cable at lowes to get the drivers side working. I also bought a long bolt and shackle to make them reach. Seems to be holding up and should be enough to pass inspection.
[ Image ]
[ Image ]
Would you remember if it was the short or the long explorer cable? you used. I'm up to this point and don't really want to shorten cables if I don't have to.
