small battery
Supermike
Post by Supermike »
I couldn't locate those Exide's... at least, not online.
I did find this one (official battery of Nascar):
78DT-M108** 12V 770CCA 950CA 120RC
http://marathon.exide.com/battery.aspx
or
http://extreme.exide.com/
Hard to find, though... lousy market penetration for a battery that is affiliated with something as big as NASCAR.
Former owner of a '67 F100 Camper Special
Current owner of a 2022 Ford Bronco Wildtrak
kid
Post by kid »
QC
Post by QC »
Almost all the batteries in this country are built by 3 companies, Johnson Controls, Exide or Deka. They all label batteries for many different companies. Delco went bankrupt and was bought by Johnson Controls. I work for Exide.
The high cranking amp batteries are OK for rigs that get used every day, but aren't so hot for something that sits for long periods. They will go dead faster just sitting than a lower CCA battery because there isn't as much acid in them. All the space is taken up by plates. They also have higher warrenty rates because the plates are much closer together which makes it easier to short out. The Nascar and Marathon batteries are available at all CSK stores(Checker, Schucks, Kragen) Nascar batteries are sold at NAPA.
Make sure you are comparing apples to apples. CCA's are cranking amps at 0 deg F. CA's are cranking amps at 32 deg. F. RC is reserve capacity. That is how many minutes the battery can put out 25 amps before it gets down to 10.4 volts. Most batteries that say 1000 amps is the CA rating, which is about 20% higher than the CCA rating. It's real hard to get 1000 CCA out of an automotive size case. They just can't get enough plates in there.
69 F-100 Ranger 302
A_G
re: small battery
Post by A_G »
you missed the question. very simpley. can i turn over the motor with a small battery. Its not going to be a DD for awhile. it needs 4 new rims. New tires. new electrical systems. ETC ETC>
"The happiness of a a man in this life does not consist in the absence, but in the mastery of his passions"
~Alfred Lord Tennyson~
Caterpillar Diesel Haul Truck Mechanic
ToughOldFord
re: small battery
Post by ToughOldFord »
Yes, you can.
