Manny's 67' F-250 Highboy Restoration
popeyes71
Re: Manny's 67' F-250 Highboy Restoration
Post by popeyes71 »
You do have your work cut out for you but it could be worst. Like what was mentioned, try not to get overwhelmed and focus on one thing at a time. It will all be worth it when you get her finished. Document the build and keep us up to date! We all are rooting for you!
-Popeye-
1971 F-250 4x4 Highboy
Manny
Post by Manny »
Thanks y'all i am not scared to death of it know its just going to take some welding wire and some other panels....
As for progress i forgot this update the front hanger. Still pondering adding a inch or so to the hanger but first i want to mock out stock height. The driver side front hanger was hammered. Bolt obviously was turning in the hanger and egged it bad.
Mocked it to the bottom of the slot where it was original. Heavy black oxide 9/16' washer.
How i had her held up to get it right.
Welded the washers on inside and outside then welded the inside up where it was egged. So metal filled in washers added to add strength via thickness.
End results...
Need to get some new springs the old ones are hammered. Then i can get a better idea of ride height... All for now. :D
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
cdnwillyg
Post by cdnwillyg »
You know what they say " Everything starts with a good foundation!" :thup:
I really like your rims Manny!
Stony Plain, Alberta, Canada
:drive:Willy
Manny
Post by Manny »
cdnwillyg wrote:You know what they say " Everything starts with a good foundation!" :thup:
Too bad they ain't staying then... :lol: I am going more old school steelies or the new indy mags that are out. Don't worry the wheels are going on some thing special.... 66' crewcab......
briansbronco
Post by briansbronco »
I had a couple sets of 16" original steel pies I have been holding back for special projects too. I think they are the best looking setup out there. Especially stuffed into larger off-road tires. I just love the look
1970 F250 4x4 SC Flatbed.
1968 F350 DRW Service body.
1969 F250 4x4 SC DRW
"People sleep peaceably in their beds at night because rough men stand ready to do evil on their behalf"---Orwell
cdnwillyg
Post by cdnwillyg »
Sorry Manny wrong place my bad. :oops:
:drive:Willy
hfdco4
Post by hfdco4 »
Great to see progress. When I had to fix the elongated holes on my front spring perches, I had a friend make some inserts. But I am sure you saw that in my posts. I am so happy I built the new front cross member though, check that out and see if you like sir. :thup:
:fr: FE390PC
hfdco4
Post by hfdco4 »
Manny, I just realized I don not have the lower shock mounts for the front axle. If you have some can you send a pic so I can see what they look like please?
:fr: FE390PC
Lone Ranger
Post by Lone Ranger »
You got a 66 crew?!! Some guys got all the toys. What route you going for front springs? Mine are saggy and I'm not sure if I want to get stock ones or the super duty swap.
Kyle
Manny
Post by Manny »
hfdco4 wrote:Manny, I just realized I don not have the lower shock mounts for the front axle. If you have some can you send a pic so I can see what they look like please?
Sure thing I will try and get that tonight.. also got post more updates.
Lone Ranger wrote:You got a 66 crew?!! Some guys got all the toys. What route you going for front springs? Mine are saggy and I'm not sure if I want to get stock ones or the super duty swap.
I do not have a 66' crew my friend Vann does and I am helping him with the build gonna be sweet 66' crew on a 94' 4x4 turbo idi diesel chassis with overdrive the works.
I posted in your thread on the springs going to use some from www.generalspringkc.com ,and then if not happy will build lift into my crossmember.I got the bed side tool box mocked in and tacked will post pictures tonight!!
Manny
Post by Manny »
Here is my update from the first day the weekend when it was snowing. The bed I have is very solid but very crooked and does not have a tool box.. So....
Stripped it away gotta say the 3m pads are the best work well on air buffer.
Another tool that works well is the Harbor freight stud gun. Two years or so various projects and been happy with it.
Had to make the bump look like a porcupine
Also had to beat I mean beat the lower braces back into shape to push the bottom out.
Gotta pull more on the bump yet but go the bed side right with the cab where I'm comfortable cutting it open to do the toolbox.
More on that later.
hfdco4
Post by hfdco4 »
Nice work sir. You will love the side tool box.
:fr: FE390PC
popeyes71
Post by popeyes71 »
Some good progress! I wish I had the tool box on my truck.
-Popeye-
Manny
Post by Manny »
popeyes71 wrote:Some good progress! I wish I had the tool box on my truck.
got enough parts to do a second....... :hn:
briansbronco
Instigator.....
Only ones I have ever seen locally were rusted to hell and gone.
