nonblinking drivers side blinker
- OldBlue67
Ok this is probably a simple deal, but I'm not familiar with wiring/ electrical stuff. I was testing my lights today and found an issue with my drivers side turn signal. The drivers side parking lights work, but when I turn on the turn signal the lights dont come on or blink. Its only the drivers side the passenger side works fine
Any thoughts for the electrically inept?
~Liz
Old Blue Truck is Old and Blue
Ugly as sin but dont get in my way VA-ROOOOOOMMMMM!!
- 72hiboy4x4
Check the light to the front/rear on the same side, its probably burned out.
its a saftey feature on these trucks to tell you when one of the lights is not working.
re: nonblinking drivers side blinker
More than likely just a bad bulb and/or corroded socket. Clean out the socket and use a little dielectric grease for protection.
- ICEMAN6166
its a dual filament bulb, one side could be broken
- OldBlue67
Re: re: nonblinking drivers side blinker
I'll bet ya thats all it is. I hadnt realized it was dual filament so to me light coming on = bulb goodICEMAN6166 wrote:its a dual filament bulb, one side could be broken
~Liz
- 390Nut
Gotta learn sometime, Liz.OldBlue67 wrote: "yah I had to get help from the guys to change my lightbulb"![]()
`69 F100 390 4spd driver
- OldBlue67
~Liz
- ICEMAN6166
last time i bought a pack of 10 bulbs they all said Hungary on the metal part, couple of them did not even work new
- wildcard
I just went through the same thing on the left front. Turned out to be the socket. The insides are shot so it has no more spring left to it. I finally got it working so I left it alone.
Looks like the whole headlight bucket needs to come out to get in there to replace the socket. Not worth it as long as it's working.
- Supermike
What does it mean when the signal lights come on, but they don't blink? Sometimes they might click once, but they have been clicking more and more slow, and now they just stay on when I hit the signal. Left blinker gets a solid-on light, right blinker gets the same.
Of course, if I flick the signal bar up and down, it sort of works like a blinker by turning the light on and off and on and off and...
Former owner of a '67 F100 Camper Special
Current owner of a 2022 Ford Bronco Wildtrak
- bluef250
If blinkers work slowly, the relay does not enough power to function properly. Possible reasons include a bad ground, someone may have installed a heavy duty flasher (for towing or whatever reason), the flasher is bad, you have a bad connection (corroded or loose), a low voltage problem, or other problems.
- Supermike
Thanks...
I have a Camper Special... would that have a heavy duty flasher by default? I haven't looked to see if it's been replaced, but I can't imagine a flasher lasting 40 years...
Are there any differences between a heavy duty flasher and "normal" flasher, as far as the connections?
- Supermike
Can anyone tell me a bit more about the turn signal flashers on the 67?
When I try to look them up on AutoZone or NAPA, they both tell me they aren't available. As I understand, the 67 had a square one-year-only kind of flasher, but the round ones from later are compatible? Is that correct?
Does anyone know by any chance what part I need to pick up?
Thanks!
Thanks!
