battery hold down ???
ezernut9mm
Post by ezernut9mm »
did our battery holddowns (the piece across the top of the battery) come from the factory rubber dipped?
DuckRyder
re: battery hold down ???
Post by DuckRyder »
Yes.
Dennis Carpenter has a plastic one that works well. It is dimensionally the same as the metal one, unlike the later plastic one.
ezernut9mm
thanks for the response. i have mine out and it had corrosion starting under the rubberizing so i cut it all off and cleaned it the best i could. i hit it with some rust converter and am going to redip it and see if it holds out. it is still 95% so i want to keep using it if it will last.
