What gear ratio to use?
HOWDY69
Post by HOWDY69 »
I have decided on a Truetrac for the 1969 F250. Should I change the rear end gear ratio while I am at it? It has a 9.6 CR FE410 with a 4.10 Dana 60 32" tires. Mostly daily driver, not much towing, more interested in fun factor than mileage.
jschreiner
re: What gear ratio to use?
Post by jschreiner »
With a 32" tire 3.50 would be the highest I would go. A 3.73 gear with 32" tire is almost like having 3.25 gear. Jay
averagef250
Post by averagef250 »
I'd keep it 4.10.
HOWDY69
Post by HOWDY69 »
The Fordfe site recommended the following link.
http://www.richmondgear.com/calculators.html
I played around and it looks like the 4.10 is a good ratio.
Street Performance with 4.10 gr and 31.7 in tires
55 mph 2390 rpm
60 mph 2607 rpm
65 mph 2825 rpm
70 mph 3042 mph
75 mph 3259 mph
Drag Performance
Current setup: 92.8 mph
4900lbs, 305 hp, 4044 rpm, 31.7 in tires, ideal gear ratio 4.11
With headers: 97.6 mph
4900lbs, 355 hp, 4254 rpm, 31.7 in tires, ideal gear ratio 4.11
ima71 trucks are older
Post by ima71 trucks are older »
if you use it in town a lot, stop and go traffic and the like 4:10 will give you the best milage.
68 F100 soon to be on an 80's 4x4 frame and 300-4spd
69 F100 300-4spd
78 F150 300-3spdOD
