I have a 3-speed Tranny with T-85 O/D out of a 1966 long wheelbase 352 CI F-100.
It has a bolt on yoke, I would like to use a slip yoke, my 65 F-100 is short wheel base and I want a one piece driveshaft.
What is necessary to do this ??
Thanks.
Richard.
1966 3-speed with O/D bolt on yoke, want slip yoke.
All your Ford are belong to us
re: 1966 3-speed with O/D bolt on yoke, want slip yoke.
Don't think you can do that. You will prolly have to keep that output yoke and have a driveshaft made up with slip splines in it to accomidate the movement.
Fred
Fred
I agree, the slip-joint driveshaft would be the ticket. Since transfer cases on 4WDs don't have a slip yoke, the rear driveshaft (between the transfer case and the rearend) use a slip-joint driveshaft. If you're lucky, you could even find one meant for a SWB 2WD truck with a manual 4-speed. Here's a few graphics for the visual. The first two are shots from a SWB 4WD:
![Image](http://www.fordification.com/board/driveshaft_4x4_tcase2rearend.jpg)
![Image](http://www.fordification.com/board/driveshaft_694x4.jpg)
![Image](http://www.fordification.com/board/driveshaft_diagram2.gif)
- cghstrojan08
Wow, I am always amazed with Keith's knowledge and having a picture of about everything. ![Not Worthy :bow:](./images/smilies/icon_notworthy.gif)
ROBERT
Member #1076
1968 F100 SWB 360
1969 F100 LWB 360 "Ol' Blue" - Sold
1976 F350 Trailer Special, Extended Wheel base, 460
http://s9.photobucket.com/albums/a75/cg ... ld%20Blue/
![Image](http://i9.photobucket.com/albums/a75/cghstrojan08/IMG_2236.jpg)
![Image](http://i9.photobucket.com/albums/a75/cghstrojan08/ford.jpg)
Member #1076
1968 F100 SWB 360
- AlleyCat
Richard, I'm not sure if Ford used a 3 speed o/d with a slip yoke. I have 2 of them..One was from a bump the other from a slick.Both were short beds.Both have bolt on yokes.The bump had an FE.The slick had a Y-Block. ![Smile :)](./images/smilies/icon_smile.gif)
Clay
Thanks for the info!!!
I would have thought that the slip joint went to the rear end joke......
That helps, I have half of a 2 piece driveshaft that had a carrier bearing.
I have the half with the slip joint on it, it has a threaded cover like in the picture.
After I rebuld my trans, I will get a drive shaft build with the slip joint in it.
spartman, I got the slip joint form a 70 or 80 something Ford truck.
It had a 2 piece driveshaft.
Richard.
Richard.
