Driveshaft Length
Driveshaft Length
I probably should know this, but.....is the driveshaft directly interchangeable, regardless of rearend? I need to replace the Dana-60 5-lug (in my '68 longbed) with a 9-inch (not my first choice, but I just need to get the thing driveable so I can quit paying storage on it!). It will be a LOT easier if I can re-use the original driveshaft.
Stuck In the Mojave
but my heart's in Idaho!
Dad's 1968 F100 with:
-1972 8100 GVW Axles added
-Power Steering Added
-Power Brakes Added
http://www.fordification.com/galleries/ ... ?album=554
-Power Brakes Added
- RedneckTexan
- iamthewreckingcrew
re: Driveshaft Length
A tape measure would tell you. Sorry I don't know the answer.
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
- RedneckTexan
Re: re: Driveshaft Length
That would work, if the donor truck wasn't a stripped-out junker (nothing to measure!). I'm a LITTLE smarter than that!iamthewreckingcrew wrote:A tape measure would tell you. Sorry I don't know the answer.
Stuck In the Mojave
-Power Brakes Added
-Power Brakes Added
