fwd crossmember
fwd crossmember
I am having trouble reinst. my fwd x-member after a tranny rebuild. Is there any tips on how to get that thing back in there?
re: fwd crossmember
Kind of late I guess but make sure you are not putting it in backwards. Only goes one way
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- Wes
I always used a porta power to relieve a little tension to aid with removal and install. Don't get carried away.
Wes
67 F250 High boy
69 Bronco
If you can't see fit to stand behind Our Troops...Please stand in front of them
67 F250 High boy
69 Bronco
re: fwd crossmember
i took mine out 20 yrs ago and never put it back
- ToughOldFord
re: fwd crossmember
I wouldn't leave that off for anything, it's there to brace the frame where it supports the radius arm mounts. Without it you're going to stress the frame, not to mention wreck your alignment.
- MadMaxetc
Re: re: fwd crossmember
Dito that...not a good idea.ToughOldFord wrote:I wouldn't leave that off for anything, it's there to brace the frame where it supports the radius arm mounts. Without it you're going to stress the frame, not to mention wreck your alignment.
To get it back in you can "shave off" a little on each end with a grinder and use a BFH to "adjust" it back into place
Dan
FORD Girl
Photobucket Pictures
FORD Girl
