360 c6 internals different from 429 c6?
1971ford
Post by 1971ford »
we have a 429 engine that has a c6 attached to it that feels uhappy. we also have a c6 thats attached to a 360 that works great which we can use.
can we swap the c6 (the one that was connected to a 360) guts into the other c6's internals (the c6 that was attached to a 429)? :?
are the 429 c6's internals more beefy or different spline or anything.
-Ryan
convincor
re: 360 c6 internals different from 429 c6?
Post by convincor »
both the same
Why go thru the trouble of swapping to put used parts in when you can get a rebuild kit for $129?? http://www.napaonline.com/MasterPages/N ... tch+Plates
"Still Plays With Trucks"
DuckRyder
Post by DuckRyder »
Define "unhappy". :wink:
BobbyFord
Re: 360 c6 internals different from 429 c6?
Post by BobbyFord »
1971ford wrote:we have a 429 engine that has a c6 attached to it that feels uhappy...
Perhaps some group therapy is in order...:D
1971ford
Re: re: 360 c6 internals different from 429 c6?
Post by 1971ford »
convincor wrote:both the same
sheesh theres like a million seals in there :eek:
-Ryan
MadMaxetc
Post by MadMaxetc »
Looks a LOT worse than it is. If you take your time and keep your work area clean and orginized, you will be fine.
Dan
FORD Girl
Photobucket Pictures
convincor
Post by convincor »
Do you want to go thru all that work and use used parts to save $129??
Either that or bite the bullet and buy a trans-
http://store.summitracing.com/partdetai ... toview=sku
after all, it's only money and your Dad can make more :D :D
1971ford
Post by 1971ford »
ill talk to dad once he gets home. i'll try to rebuild it buy i know i would need my dad's brain at times :D
convincor wrote: after all, it's only money and your Dad can make more :D :D
very true :thup: :lol:
-Ryan
RedneckTexan
Post by RedneckTexan »
:lolprev: :lolprev: :lolprev: :lolprev:
John
68 F-100~68 F-350~69 F-250~69 F-100
76 F-150~78 bronco~78 bronco
http://oldfordcrewcabs.com/
flyboy2610
Post by flyboy2610 »
Buy this, too:
http://www.amazon.com/Haynes-Automatic- ... 1563921707
Takes you step by step through the process.
flyboy2610
Buy this, too:
(Double post. Please disregard this one.)
binder56jd
Post by binder56jd »
rebuild kits & performance parts and how to's
http://www.c6-c4.com/
just one of several similar sites
go for it :thup:
make that trans smile
now serving #235
BobbyFord
Post by BobbyFord »
I rebuilt my first trans when I was about 18. It was a C6. I just laid everything out in order and followed the manual. I've rebuilt a ton of transmissions since. I don't even use the manuals anymore (except for torque specs or clearance specs). The best way to learn is to tear into one. (I'm Ford trained now, but I wasn't at the time of my first teardown). Also, if you've got a digital camera or video cam, you may want to take pics or vid to help you along.
1971ford
Post by 1971ford »
dad agreed with rebuilding the tranny instead.
so thats what were doing.
does the torque converter out of the 360's c6 work fine in the 429's c6? since we know the 360's c6's torque converter is good we might as well swap that in the 429's c6 while were down there. if its interchangeable.
-Ryan
RedneckTexan
I think so, but you better check with another member just to be on the safe side :wink:
John
