I just spent $700 for newer A/C parts(Compressor, Clutch, Dryer, and r13 freon and labor. I wasn't too impressed with the coolness coming thru the vent;however I could see frost inside the vents but it just didn't seem too cold. Anyway today is the second day with my "fixed" system and NO cold air today and NO frost inside the vents....I opened the hood and noticed oil on top of the compressor around a fitting that the hose goes into...I guess that means all my r13 escaped from the fitting? My mechanic friend said that he put a compression test on the system and it showed no change from 45lbs....but today I assume that'd be different?? Anyway since I have tried r13 should I now try r134 when I get a new fitting?
Thanks
