what trans for a 347
hi all i have a 302 that im stroking to a 347 should what trans should i go with i have a t18 in it should i go with a c4 or could i keep the t-18 in it this is my first build and i want to do it right the first time so the wife does not put me in the dog house
Re: what trans for a 347
i think its around 4600
its a lighter duty truck than a full 5000 lb gvw truck. i guess it depends on what your going to do with the truck. a c4 will rob engine power from the truck. you will eat up more horses with an automatic than a standard.
- basketcase0302
My1stF-100,
I just sold the perfect tranny for your 347 last week, (a C-6 with the small block bellhousing is bullitproof for that many ponies).
IMO the C-4 will hold up ok, but have them add an additional set of clutches when it gets rebuilt.
Dustin can explain this a little better I think.
Basketcase
Basketcase
i plan on building a mild compression 347 9.5:1 or 9.7:1 and put a 174cid blower on it
id love to go bigger but no money for it im machining the block my self i have a eagle 347 rotating assemblie already wife got me for my b day that was 1,809.95 so i need to use it plus the new plus the new ignition i just got that was 499.95 and the headers was 249. and the new starter and milodon oil pan and pic up pump drive shaft and windage try that was 379.00 and my valve covers was 349.00 so i have spent like little over 3286.00 so far on this motor so i dont want to lose what i have spent on it but i do agree with you all bigger would be better
- averagef250
That's a lot of coin. How are going to machine the block yourself?
i have my own machining shop have been doing it for 2 years and 1 year school
- FORD428CJ
Sounds like a lot of coin to me!!! Also you may want to make sure that you are using Forged pistons and have your ring end gap right for a Huffer set-up! You may already know that but keep it in the back of your mind when building your engine.
Wes Adams FORD428CJ
Built Ford Tuff With Good Ford Stuff
79 F-250 X-Cab 4x4 6.9 Turbo Diesel
64 Falcon X-Ram 428
55 FORD Truck 4-link Rides on air with X-Ram 428
67 Stang 351 C/J
2000 Yamaha V-MAX VMOA#4277
64 Falcon X-Ram 428
67 Stang 351 C/J
- papabug71
If your dropping that kind of cash on the motor, then the trannie is a no brainer. Built C6 all the way. You could roast em' off all day long & never have to worry about a trannie ever again.
I am with averagef250. A truck 4 speed will be worthless bolted up to that specific motor. I would go with a C6 & be done with it.
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
thanks for all of your posts so c6 it will be and thank you all
- FORD428CJ
Any time!!!
Wes Adams FORD428CJ
64 Falcon X-Ram 428
67 Stang 351 C/J
64 Falcon X-Ram 428
67 Stang 351 C/J
