t5 tranny in a 69
t5 tranny in a 69
I have a t5 trans out a 5.0 mustang with worked gears and a new clutch does anyone know if there is a way to install this into my 1969 100 race truck? it has a 360 5.9 put out to a 428 and a 3spd on the floor.
- averagef250
Re: t5 tranny in a 69
A 428 will put world class T-5 gears and shafts approximately 6" into the asphalt on the first launch.
A T-5 is a small block car tranny. Sell the T-5 and get a toploader or an aftermarket 5 speed.
- MadMaxetc
At best a T5 will take 305ft-lbs. A built 390 will be over that.
I would look for something dirrerent and sell that T5.
Dan
FORD Girl
Photobucket Pictures
FORD Girl
If you had an Astro kit or a Gforce kit installed in the T5 it would be able to take the punishment. Final cost on those kits are about 2200 bux. Then you gota get a bell housing that would fit the block and the T5. Again you would need to consider input shaft length.
I think hooking a T5 to a big block is just cost prohibitive.
You can always drop a 5.0 into the truck but I'm not sure how happy you would be with the performance lol.
- Dragon
A NV4500HD is 2450 with clutch disc and will take a hammer drop from 450 horse motor without breaking.
Old Fords Rule
Was a Ford Service Tech
98 Volvo S70 2.4T Auto
71 Service manuals Volumes 1,2,3 and 4 So ask away.
My Gallery
Spark test
My Gallery
Spark test
- Dragon
Sorry I did not read race truck Top Loader RUG code wide ratio is kick ass in a race truck. All of mine used them with 3.89 Zoom gears in the rear end and 33 inch tall tires gave me 140 mph at 5200 rpm.
Old Fords Rule
My Gallery
Spark test
My Gallery
Spark test
