We are moving back into our home tomorrow! The contractor has done a Rockin job!
It has been a loongggg five months..
I will need to seal the garage floor and we would like to find a sealant that can repeatably stand up to oil, gas etc??
Thanks
Garage Floor Sealant?
- DGrant09
09", F350, Cabelas, 6.4L
72", F250, CS, 390, 2 WD
- 69FLATBED
Re: Garage Floor Sealant?
Do not use ACE floor and garage paint I used it in my shop and it all is peeling up now,and looks like #@%!
Troy
_________________________
2000 F350 4x4 Crew Cab PSD
1969 F350 Flatbed 360 4spd DRW
!968 F250 4x4 Crew Cab SWB
Love my diesels hope to be gasoline free soon!
- flyboy2610
Whatever you use, do not skimp on the prep job!
Also, double check with your contractor as to when the concrete can be sealed. I read somewhere that sealing concrete less than a year old isn't recommended, as it hasn't really cured properly before then.
- DGrant09
Fortunately this was not a new build but a re-build after a major fire in January, so no worry's (at least it was not my mechanic skills that started the fire ).flyboy2610 wrote:Whatever you use, do not skimp on the prep job!
I saw a rustoleum garage floor sealant/paint kit at Lowes today.. I am a bit concerned about paint. As 69 Flatbed mentioned, I'd hate to see it start peeling..
Thanks for the input!!
I've been wanting to get the U-Coat It system. You see in advertised in most of the car mags. It's a two part epoxy, and you can put those flakes of color in it. The reason I haven't is because of running studded tires in the winter, I can't imagine any floor coatings holding up to that.
55F100
55F100
- DGrant09
Fordnatic,
I had not thought about the studded tires come winter.. It looks as if we'll just use a floor sealer and be done with it. We're back in our home now and the garage is slammed with furniture and boxes so it'll be a week or two before we can get to it.. Wish'n I was fishin this weekend! Maybe tomorrow!!
