On the front of the t-case (closest to cab) there is a thick access panel looking deal that has several bolts around it. Almost like some access panel or somethign. Oil is spewing from it... So I'd like to simply pull the thing off, put a new gasket on, and be on my way.
My question is what the heck is inside the cover and if i can truly simply just pull it off and put it back on or if htere are parts that have to come off with it or something? I just want to know what to expect is all.
this is the only pic i have of the t-case. you see the cover on the right side (which would be the front of the t-case when installed)? It is simply between the short driveshaft that goes to the 4spd and the output that goes to the front axle.
