Don't know how many drill bits you all go through but man I have gone through a ton and their not always cheep ones. So before I dumped my drill bit drawer into the garbage I thought I'd give this tool I saw at Lowes a try. $79.00 seems a little steep but I know it would be worth it if it works, and boy does it ever. I ran all my drill bits through it in about an hour and the are all like new if not better. If you use a lot of drill bits you might want to look into it, just my
Drill Doctor really works well
- FoPAR
"FoPar" because I love Fords and Mopars so just call me FoPar...
- Mancar1
Re: Drill Doctor really works well
Been useing that nifty Doctor for a few years now. Yes, I agree it works very well.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- BobbyFord
Drill Docs work great. Well worth the price.
I usually sharpen mine about once a year & place them according to size.
When I dull one I TRY to throw it in the dull bit bucket ( this keeps me from wasting my time later by installing a dull
bit & having to remove it again).
You can't drill with a dull bit & can't saw with a dull blade.
- basketcase0302
Thanks for the feedback guys! I've been needing one of these for years, (20-30 HSS drill bits that won't cut anymore). It will pay for itself in the first day i buy it.
Thanks again!
Thanks again!
I've got one too, and love it.
HOWEVER...I bought a set of cobalt drill bits last spring (Amazon, $79.00) and they are FLAT OUT AMAZING. Drilled through the F150 frame (for a hitch mount) in no time flat.
Highly recommended if you value your time.
or, money.
or, money.
- BobbyFord
The key to drill bit life is drill oil and speed control. That is of course if you purchased quality bits to begin with.
- cowbay
You are right. The key is not to overheat the bit. Also if you can find a drill press. I bought one for my shop at the auction for a hundred dollars and the bits last three times longer than doing it by hand.BobbyFord wrote:The key to drill bit life is drill oil and speed control. That is of course if you purchased quality bits to begin with.
- 68F100Merlin
Some of the best tool money I ever spent.
