What tire size do you recommend?
I just orderd some new wheels for my 67 Merc M100 Ranger. 15X7 for the front and 15X8 for the rear. Now I need to know what tire size will look best on the wheels. I plan on buying BF Goodrich radial TA's. I was thinking 275 60R/15 for the rear and 245 60R/15 for the front. I do have power steering as well. The stance is original and not lowered. Any suggestion and photo's would help.
Thanks
Thanks
- mybros71
Re: What tire size do you recommend?
If you don't already, knowing how to decipher the P-metric tire size and convert it to inches is a good thing to know.
Example 275/60-15
---275 means the overall width of the installed tire will be 275mm wide. 275mm = 10.8 inches
---60 means that the height of the tire is 60 percent of the width. So... 275mm x .60 = 165mm and 165mm = 6.5 inches
So... 6.5 + 6.5 + 15 = 28 inches high overall. Approximations of course, but close.
A 275/60-15 tire is approximately 28" by 9"
Example 275/60-15
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
1971 F100 2wd Prerunner Project (Daughter's)
1971 F250 4wd "The Beast" (Son's)
2007 Toyota Tundra 4wd. (Credit Union's)
Seriously, the best truck I've ever owned, without exception.
Thanks. That is good to know. I will make note of your email and put it in my file for my truck for reference!
I am also wondering what people think looks cool but is still nice to drive/steer.
- DuckRyder
Radial T/A Specs
7" is the minimum wheel width for a 245/60. I would try to avoid running a tire on the minimum recommended width because in my experience they wear strange and also it doesn't look good to me.
I would probably go with a 225/70 or even 235/70 if you want it to look fatter...
Sounds good. I need to get a visual before I make a final decision. I might need to go to a tire shop and put some different sizes side by side to help with my decision. Of course the tire shops around here do not stock BF Goodrich Radial TA's
I tried to look up on the photo forums but was not to successful
Dave
Dave
- F100builder
I have 275/60's on 15x8's and 245/60's on 15x7's...I've dropped mine with DJM beams and flipped hangers too. I LOVE the look!
Patrick
- F100builder
BTW...I have Uniroyal Tigerpaws on mine and had them balanced on the inside only. I was all for the BFG's but these were a little less $$$ and fit my budget better at the time. FYI, I have power steering and a big block and it steers just fine and is a blast to drive. No complaints here.
Patrick
Love your truck and I also think the tire size looks great. Thanks for the photo's!
Dave
Dave
- mybros71
I don't mean to hi-jack this thread but F100builder's bump is friggin' awesome. Perfect profile and color combination. Big Props.
I totally agree.
- F100builder
Thanks a million for the kind words! They mean a lot as I've really busted my butt on this truck and I'm pretty proud of the work I've done! She's not perfect and also not done but it's where I want it for now until I do a 'real' rebuild.
Patrick
- mybros71
Before we start hi-jacking this thread, check out this sweet rig.F100builder wrote:Thanks a million for the kind words! They mean a lot as I've really busted my butt on this truck and I'm pretty proud of the work I've done! She's not perfect and also not done but it's where I want it for now until I do a 'real' rebuild.
http://www.fordification.com/forum/view ... 22&t=65241
- F100builder
Yeah, we've been PM'ing each other so I didn't post the link here...it's supposed to be about his tires!
Anyway, I think he's got his mind made up but thanks for the compliments!
Check out SomersMerc's Merc! It's a great start to another COOL '67-'72 FORD!!!
Patrick
Hey guys I really don't mind the posts of your builds. I really enjoy seeing all the great photos. It just makes me want to do even more to my project however I do not have the mechanical talent like you guys. Anyways I really think your truck is cool.
I have decided on the tires after talking more with my wheel supplier and going over different options and comparing heights, widths etc to what I currently have on the truck. I will be going with the same as in your photos.
245 60 15 on 7 inch for the front and 275 60 15 on 8 inch for the rear. I picked up the wheels yesterday. I will post photos when the tires arrive in 7-10 days and after I get them mounted.
Thanks again for all the great suggestions.
Dave
Dave
- F100builder
Thanks again! Don't forget to show us the new rollers!
Patrick
