heat problems
samericsson67
heat problems
Post by samericsson67 »
for the past few months or so, my heater doesn't turn off. seeing as it's hot here in Pennsylvania in the summer it's nice to not have the heat on. I've solved the problem kind of by just taking the fuse out. anybody know what may be causing this?
basketcase0302
Re: heat problems
Post by basketcase0302 »
Look at part #18494 in the upper center of this diagram. Most the time the heater valve has stuck open, (or been removed by a PO) causing the coolant to constantly flow through the heater core:
72Highboy
Re: heat problems
Post by 72Highboy »
When the fuse is in does the heater motor continue to run or is heat just coming through the vents?
Joshua
aka Young Gun 8) :drive:
FE - Famous Engine
(Brandi) 72 F100 360 5.9L Sport Custom 6" Lift
U.S. Army Veteran/11B
