PS column
danno
PS column
Post by danno »
Needing a automatic, P/S column for a C-4 transmission ! Anything from a 1974 on down will work, needs to be in good shape :D
65 f-100 4wd short bed 360engine c-6 tranny
FORD-F250-4x4-1972
Re: PS column
Post by FORD-F250-4x4-1972 »
Sent PM :fr:
wrongway
Re: PS column
Post by wrongway »
I need the same thing, but I was thinking a C-6. If you have another column or know where one is now would be a good time for me. I have the 302 dummied up in the engine compartment and haven't made a definate decision on C-4, or a C-6. Thanks, Gary
68 Ford F-100, two wheel drive short bed. 46k original miles, was a 240 six cylinder 3 on the tree. Changed to a 347 stroker with a C6, 03 Crown Vic front end, lunar green. Torn completely apart for a frame off fun daily driver project.
BobbyFord
Re: PS column
Post by BobbyFord »
As far as I know, the automatic columns are the same, only the linkage varies.
Diamond N
Re: PS column
Post by Diamond N »
wrongway wrote:I need the same thing, but I was thinking a C-6. If you have another column or know where one is now would be a good time for me. I have the 302 dummied up in the engine compartment and haven't made a definate decision on C-4, or a C-6. Thanks, Gary
I have a nice TILT column still in a '79 F150, in case you would like to upgrade to tilt. The truck has a C6. If you are interested (or anyone else), just send a PM or better yet, an eMail for more details.
68 F-250
79 F-150 4x4 (parting out)
79 Bronco (parting out)
danno
Re: PS column
Post by danno »
sent PM Thanks
FordTruck
Re: PS column
Post by FordTruck »
I've got one out of a 70 with PS but the collars a little messed up.
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
danno
Re: PS column
Post by danno »
FordTruck wrote:I've got one out of a 70 with PS but the collars a little messed up.
thanks but I got one the other day... :thup:
