Needed
Needed
This is what I have, there is a tube that connects from the spacer to the valve cover breather, I need that tube ( I don't know what is called ) I need that tube and the valve cover cap, for a 360 ci. If any one has one let me know thanks
Re: Needed
Anybody
Re: Needed
That's for your pcv valve.
The factory had a molded rubber hose, but you can use emission hose.
it's sold by the foot at "good" parts stores. it should be 1/2 or 5/8 inch diameter.
in the meantime you can plug it so it'll run without a vacuum leak.
Re: Needed
I 'BELIEVE' those are reproduced. Dennis Carpenter comes to mind.
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..
