On a two part drive-shaft where the rear shaft pushes into the shaft from the carrier bearing there is a part that screws on to the input shaft.inside of this is a kind of serrated washer that fits over the splines in the shaft and a cork seal. I need one of those washers and a seal if anyone has it. I took mine apart to clean and paint. I ruined the seal thinking it was just grease. Then I promptly lost the washer. Thanks.
