Purchased $400
DMV Transfer & Nonop $50
Driver Window $15
Regulator $15
Seat $25
Carb Rebuild Kit $17
Tank Solution $15
Fuel Pump Filter $5
In Line Filter $4
Rear Brake Shoes $24
Rear Brake Drum Turned $16
Rear Brake Drum New $31
Fuel Pump Bowl,Washer Bag,
Battery Hold Down Clamp & Bolts,
Fuel Gauge Sending Unit, Turn
Signal Switch $142
Shift Collar, Gas Cap, Front Wheel
Bearings and Seals, Axle Snubber $88
Air Cleaner Assembly $45
Total To Date: $856
![Image](http://i147.photobucket.com/albums/r296/apexxn/1967%20Ford%20F100/001_zps6d6f4bdb.jpg)
![Image](http://i147.photobucket.com/albums/r296/apexxn/1967%20Ford%20F100/010_zpsb203fc64.jpg)
Plexiglass Rear Window
![Image](http://i147.photobucket.com/albums/r296/apexxn/1967%20Ford%20F100/001_zpsa61eabd5.jpg)
![Image](http://i147.photobucket.com/albums/r296/apexxn/1967%20Ford%20F100/011_zpsc9b02b40.jpg)
Beat Down Steering
![Image](http://i147.photobucket.com/albums/r296/apexxn/1967%20Ford%20F100/001_zpsb4b9eb7b.jpg)
Ready For Paint Before Installation
![Image](http://i147.photobucket.com/albums/r296/apexxn/1967%20Ford%20F100/002_zpsfa69115e.jpg)
![Image](http://i147.photobucket.com/albums/r296/apexxn/1967%20Ford%20F100/003_zpse18516a6.jpg)
The Dash Lights Were Dim So I Pulled The Old Tape And Installed New Clear Tape
![Image](http://i147.photobucket.com/albums/r296/apexxn/1967%20Ford%20F100/005_zpscce88579.jpg)
![Image](http://i147.photobucket.com/albums/r296/apexxn/1967%20Ford%20F100/005_zpsbe8a162a.jpg)
Radio Wouldn't Turn On
![Image](http://i147.photobucket.com/albums/r296/apexxn/1967%20Ford%20F100/001_zps9bcf2532.jpg)
Soldered In A Jumper Wire And It Works Fine Now
![Image](http://i147.photobucket.com/albums/r296/apexxn/1967%20Ford%20F100/004_zps11e8e943.jpg)
