Drop it like its hot!
Mr-Dyslexic
Post by Mr-Dyslexic »
(1970 f100 swb) Long store straight need to go down 5 in the front and 6 in the rear. Drop beams will give me 3 up front where can I get the other 2? Now in the back I can't find a flip kit if someone can help me out that would be great. Also I know I'll need a c notch does anyone sell one, I can fab one up but if there is somewhere you can buy for less then what it would cost in time for me to make them I rather do that. How low will the flip kit get me 4 inches? Is so here do I get the other 2 lowering leaf spring or springs?
HIO Silver
Re: Drop it like its hot!
Post by HIO Silver »
Mr-Dyslexic wrote:(1970 f100 swb) Long store straight need to go down 5 in the front and 6 in the rear. Drop beams will give me 3 up front where can I get the other 2? Now in the back I can't find a flip kit if someone can help me out that would be great. Also I know I'll need a c notch does anyone sell one, I can fab one up but if there is somewhere you can buy for less then what it would cost in time for me to make them I rather do that. How low will the flip kit get me 4 inches? Is so here do I get the other 2 lowering leaf spring or springs?
Cuttin one quarter to one-half my net ya another inch up front but that's it before camber gets outta whack.
Axle flip? Airbagit.com carries kits as does Fatman Fabrications. Wanna try fabbing your own? Got to about page 31 of my build thread linked in my signature. There's dimensioned drawings posted of Fatman's components including the shock relocation brackets and compatible shock pns. An axle flip nets 5 to 5.5 inches of drop.
Lowering leafs are available thru Detroit Eaton Springs. Relatively expensive IMO.
Btw, these rig's rear are set two inches taller in back so the lowering needs to maintain a two-inch difference in order to set level. You knew that, right?
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
Mr-Dyslexic
Ya I want it to have a slight rake. Ok so it sounds like I can get the 6 with a flip kit and lowering leaf springs. Now for the front lowering spring and drop beams will get me 4 with out messing anything up. Is there no way to get another inch to make 5 up front with out messing with my alignment? I'm putting a 460 with aluminum head you think the weight alone will drop it another inch, so I will get 5? Also I know with some lift kits I have done say the kit will give you 3 inches but it will really give you 5 or it might only give you two. How accurate are these kit regarding that?
HIO Silver
Mr-Dyslexic wrote:Ya I want it to have a slight rake. Ok so it sounds like I can get the 6 with a flip kit and lowering leaf springs. Now for the front lowering spring and drop beams will get me 4 with out messing anything up. Is there no way to get another inch to make 5 up front with out messing with my alignment? I'm putting a 460 with aluminum head you think the weight alone will drop it another inch, so I will get 5? Also I know with some lift kits I have done say the kit will give you 3 inches but it will really give you 5 or it might only give you two. How accurate are these kit regarding that?
Not that I know of with drop beams.... However, the front can be "lowered" by staggering the tire sizes. Spec a 27-inch tall tire for the front and a 28-inch tall tire in back.
Mr-Dyslexic
Ok now let's say I egnore that it will mess up my camber if I put the 3 inch drop beams and a
2 inch lowering springs(assuming I can buy one?). What will it drive like? What are the side effects? And why and how does it mess up my camber if I go lower the 4 inch in the front?
convincor
Post by convincor »
Problem with lowering springs up front is not only throwing off camber but you also loose what little suspension travel you have as it is. You'll be bouncing off your bump stops.
"Still Plays With Trucks"
moon.dog62
Post by moon.dog62 »
In my experience both aftermarket drop beams ( aim or airbagit and djm dream beams) seem to be made so that the camber corrects itself with cut or lowered coils. In both cases we have had to cut the coils to get the camber correct on both my 67 f250 with airbagit beams and my buddies 65 f100 with djm beams. For some reason not to many people want to acknowledge this it seems an unspoken thing for some reason. In regards to a flip kit airbagit make a great kit. It can leave the rear slightly lower than the front but this is easily corrected with a taller rear tyre.
Mr-Dyslexic
Thanks moon dog! Does anyone sell 2 inch drop springs? Is there anything I can do about it bottoming out the bump stop so easily? Flip kit + lowering leaf springs & drop beams with lowering springs here I come!! 5in the front 6 in the back woot woot!
HIO Silver
Stiffer shocks like Bilstein HDs and cut the bumpstops.
Mr-Dyslexic
Ok my final question with this set up I have in mind will it be true enough to handle 600 or maybe a little more hp engine and keep it in a straight line?
BobbyFord
Post by BobbyFord »
You are going to have traction issues.
convincor
Post by convincor »
Bobby, how's yours hook with the 325's??
Mr-Dyslexic
Ok well what other options are their to get 6 inches of drop and to keep it straight on the strip? 4 link? Any others?
P.s. Thanks for the helping me out!!
convincor
Post by convincor »
moon.dog62
If you want something that will go lower and handle better front or rear try these guys.
http://www.nolimitengineering.com/produ ... ort=normal
