Hi guys,
So I've decided I would like to get rid of my drum brakes and go to disc all the way around. I'm looking for a conversion kit for the front and rear end however I'm having trouble finding one for my front end. Is there one for the closed knuckle? Any advise?
Thanks guys
Question about a disc swap
1967(ish) Ford F250 4X4. 390, NP435, Dana 24, Dana 44 front end closed knuckle 4.11 Drum brake, Dana 60 rear end 3.73 Drum brake
2005 Subaru Forrester XS manual
2009 Scion XB Auto
2009 Scion XB Auto
Re: Question about a disc swap
There is no conversion for a closed knuckle front end. If you want to swap to discs you have to swap the entire front end with a newer model D44 or perhaps a D60. I am doing the same to my 70 250 4x4.
2017 Ford Raptor
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
Ok, so clearly I'm gonna need to get an open knuckle front end, hopefully I can find one in a junk yard. I will be swapping the rear end with one with the correct gear ratio to match the front end so I can use the 4x4. I realize this isn't normally done, but would it be bad to put disc on the rear end and have the drum's on the front? I realize will need a different proportional valve. Planning on getting this one. http://www.summitracing.com/parts/wil-2 ... /overview/
Also, what are good conversion kits for the front and rear?
2009 Scion XB Auto
2009 Scion XB Auto
