lifting 68 ford f250 camper special
Moderator: Doug Comer
What would be the easiest way to lift a 2wd f250???
- 1970F250
spring spacers in the front. blocks in the rear. big tires. the one in the picture is mine. if you want it higher than that you will need to make drop brackets like boots did or bend the i-beams
http://www.fordification.com/galleries/ ... &pos=-2464
re: lifting 68 ford f250 camper special
....or if you've got some $$$ burning a hole in your pocket, you can get the Autofab 2WD lift kit.
