should I use a 10 degree shim or go with the half flip
68shortbedinmo
Post by 68shortbedinmo »
I have completed a hanger flip and I have measured and I need a 10 degree shim. My question is should I go with the half hanger ? If so what is the height difference between the two? Or should I buy the 10 degree shim that someone on here has posted a link to? Am I going to have any trouble with that large of a shim ? Any advice and opinions would be appreciated.
Thank You
http://www.jkwoffroad.com/offroadproducts.php
68shortbedinmo
Re: should I use a 10 degree shim or go with the half flip
I think what I am going to do is go lower the front first but go with the half flip and if I need more then use this. KMW Performance - Air Suspension, Bags, Cylinders, Struts
Instead of $60 on a shim that may work $100 on something that will work better. My question is do most people go ahead and do the full flip and then this kit or do they leave the hangers in the stock location?
Thanks
