69 F250 PS cooler
69 F250 PS cooler
I am contemplating installing a finned cooler from a 70 F250 onto my 69 F250 that is equipped with the Bendix PS setup. Is this worthwhile? My understanding is that the Bendix box is prone to overheating though admittedly I have not had an overheating problem. Comments?
66 F250 camper special
69 F250 Explorer
85 Mustang GT with 1900 original miles
92 Festiva with 538,000 original miles
86 E350 extended WB van
Various IH & JD tractors (5)
TT & XT500 mc's (6)
BSA, Triumph's and twenty Yamaha two strokes
69 F250 Explorer
TT & XT500 mc's (6)
- habu
Re: 69 F250 PS cooler
I have both the Bendix steering box and headers in my 69 CS. I did put some of the DEI heat tape all over the gear box to help reduce the heat because the header pipe is so darn close to the box itself. What I can't say is if it's really overheating or just hotter than normal. Drove the truck through Palm Springs and Indio a couple of weeks ago in 100+ degree weather and there were no issues. Was it because of the DEI, can't prove one way or the other. I did buy an external cooler that I should install but haven't yet. Before I start using the truck for more heavy duty/towing applications the cooler will probably go on for insurance.
1969 F250 Camper Special, 390 2v, C6, PB, Bendix PS, AC, Dana 60. 3rd owner
Soon rebuilt 390, not stock, will be swapped in.
- mrtleavitt
I was tired of scraping my knuckles on that finned cooler so I used a cooler from a dent side truck. They are conveniently hidden down lower by the front frame rail. http://cimg9.ibsrv.net/gimg/www.ford-tr ... 61da70.jpg
1969 F100 428 with T19, 3.00 9inch 31 spline w/ Detroit Trutrac, '74 frame swap successful!
http://s43.photobucket.com/albums/e356/mrtleavitt/
- SeapineF37
nice mrtleavitt
going to keep that in mind for down the road...
