Well hello guys!
Im new on the forum. But to cut to business im doin a 4x4 swap!! I got a stock ford f100 2wd and i found a whole coil over dana 44 axle with axle bars and everything. I honestly believe that its easy as a bolt on procedure. Am i right??
78 ford f100 4x4 swap
Re: 78 ford f100 4x4 swap
Ahhh , NO!Justinford78 wrote: I honestly believe that its easy as a bolt on procedure. Am i right??
It would be far easier to get the 4X4 frame and swap cabs.
The big crossmember is totally different.
- HIO Silver
Your belief is totally.... incorrect!Justinford78 wrote:Well hello guys!
Read these for info... applicable to Dentsides but the principles remain the same...
2WD to 4WD Conversion
4WOR Project: 4x4 Conversion - Three-Link Conversion, Coilovers, Dodge NP205, GM Dana 44
FTE Thread: Quadrazer's F350- 2WD to 4WD Conversion...
Four Wheeler: Project Two-By Four (4WD Conversion)
Four Wheeler: Three-link Front Suspension & Coilovers
cep62 wrote:Ahhh , NO!Justinford78 wrote: I honestly believe that its easy as a bolt on procedure. Am i right??
It would be far easier to get the 4X4 frame and swap cabs.![]()
But if my lift is significantly bigger? It would easily clear the crossmember.
