1967 f250 camper special/ hubs mount on outside or inside of the drum
trying to put things back together but i lost my good pictures that showed exactly the set up. the one picture i do have doesnt help me to know for sure. could use any help!!!!
- MadMike
Re: 1967 f250 camper special/ hubs mount on outside or inside of the drum
On the Dana floater the wheel mounts directly to the hub and the drum is behind the hub. Drum > Hub > Wheel.
IIRC the drum/hub are bolted together first.
-Michael
- eggman918
I just replaced the rotors on my 8 lug D44 in front and it required a press to R & R the studs which hold the assy together, I "think" the rears are assembled in the same manor but I have slept since i did the rears so.........................
