Does anyone know if a cab , doors and hood from a 1967 F700 are the same as our 1/2 , 3/4 and 1 ton trucks? Obviously fenders and grille are different but was hoping the others are the same. Anyone have any knowledge of this?
Thanks
1967 F700
Re: 1967 F700
The cab is substantially different. Cab mounts are different. Floor pans are different, flatter and the steering column goes through the floor instead of the firewall. Uses same seat so that part of the floor is probably the same. Hood hinges mount to the firewall instead of the inner fenders. Inner fenders are different due to hood hinge mounting as is the hood for the same reason. Fenders may swap but won't match up to inner fenders due to hood hinge mounting different. Doors may swap? Sounds like a lot of work/modification would be required.
Re: 1967 F700
Thanks Randy. Found an old 700 that was pretty good and thought they miiiiiight work. Well , that idea is shot. Back to the old drawing board.
