brake pressure differential valve
after an ill fated attempt to install front disc, I have all drums on now. the brake light is now on and I forgot what to do to get it off. I know the valve works because I had it off once and fixed the piston. 67 thanks....
Re: brake pressure differential valve
Take a look as these, hopefully they have something there to help you:
http://www.fordification.com/forum/view ... ning+light
http://www.fordification.com/forum/viewtopic.php?t=2214
http://www.fordification.com/tech/propvalve101.htm
Regards
Regards
I believe once you re-center to piston in the valve, it will go off.
yessir. just took the brake line off and the bushing and used a rat tail file and pushed it back down, off now
thanks everyone
thanks everyone
