Anyone ever see anything like this? This is with the parking lights on and hazards on. The front parking lights are not coming on. Headlight switch one click out. They were the other day but not now. Left blinker in the rear with lights on just turns the running light on and off. I'm leaning towards headlight switch. Any input?
https://youtu.be/vKB3uAu8Vt8
Truck or school bus?
- beejaytx225
1968 F-100 Ranger LB
360 w/C6
Peacock Blue
Central Texas
360 w/C6
Peacock Blue
Central Texas
Re: Truck or school bus?
I'm leaning towards bad grounds .
Make a temporary long jumper wire and hook it to the battery ground and a light base or ground and see if that helps.
- beejaytx225
I tightened the rear lamp housings, replaced a bulb, replaced both flasher relays and tightened the connector on the bottom of the headlight switch... It all works like a dream now
360 w/C6
Peacock Blue
Central Texas
360 w/C6
Peacock Blue
Central Texas
Cheap and easy.
