Trusted Mechanic in Pacific Northwest?
Does anyone have a name of a trusted mechanic they could recommend in the greater Seattle area? Someone with actual knowledge of our FE engines. I've been having a problem with a leaking rear main seal that no ones been able to fix.
- jzjames
Re: Trusted Mechanic in Pacific Northwest?
Hey, it’s not a Toyota so good luck!
- basketcase0302
The FE's are plagued with leaking rear main seals, (a driving factor of why I'm not a big fan of them).="Big Blue 72"Does anyone have a name of a trusted mechanic they could recommend in the greater Seattle area? Someone with actual knowledge of our FE engines. I've been having a problem with a leaking rear main seal that no ones been able to fix.
And the worst part is that I could see no real way to even drop the pan on our trucks, (short of pulling the engine) to address the issue).
I hope you can find an old skool shop in the area that can maybe lift the engine to drop the pan and install a new seal.
Bump...
Oregon? Maybe too far but worth the drive.
https://fespecialties.com/ Tom Lucas is an expert and trustworthy.
Thanks everyone. I'm considering ALL options!
