horn
horn
I have a set of air horns off a diesel train and I am looking at putting them on the 68. I was thinking about taping into the wire for the main horn and putting in a toggle switch so that I could switch between the two horns, do you see any problems with doing this?
- Billybobjunky
re: horn
as far as I see, nope. Long as all either horn needs to run is straight charge, there wont be any problems with splitting it between whichever you want for the moment. Should be fine.
1967 SWB 2wd F100
-'77 V8 [[[410]]]
-'74 C6
-Re-wired main harness
-Disc Brakes/Power Steering
-'77 V8 [[[410]]]
-'74 C6
- 68F250
re: horn
Train horns? How wimpy! You need one of these, yeah it's got a hemi.
Barry
re: horn
I'm thinking with something that big you might want to install those with a relay, depending on how much juice they'd need. (I'm talking about the train horns, BTW. Barry's air-raid siren looks to be fully self-contained.)
That air-raid siren would be the perfect way to get the point across to tail-gaters, wouldn't it? Just load it into the back of your truck facing rearward, and then let 'er rip....it would probably peel the paint off the hood of the guy behind you, though!
- Yota
re: horn
man, that thing is a beast...
alvinator, i put a air horn from a big rig on my toyota with a switch like you described, so i could switch between the air horn and stock horn. no problems whatsoever, it worked great.
1968 F-100 4x4, 390 4spd. 35" bfg m/t's -FOR SALE!
1980 Toyota 4x4 - new engine is in!
my picture gallery
my picture gallery
- Big D's 69
Re: re: horn
Now that is a horn.68F250 wrote:Train horns? How wimpy! You need one of these, yeah it's got a hemi.
re: horn
I wonder if there's a jack for an IPod on that Air Raid Siren.....hmmmm.
- bleedfordblue
re: horn
wait a minute... how does an air horn run on an electrical circuit??? big trucks have engine driven air compressors. you will have to find a small electric compressor to run an air horn.
I'd rather be shooting yankees....
and terrorists.
and terrorists.
- Yota
re: horn
i put together an on board air setup and used a York a/c compressor from a Volvo, and it's set up to pump air instead of freon. so it's engine driven, and FAST. i have a 3 gallon tank mounted under the bed of the Toyota, and the compressor will fill the whole system (tank, lines, etc..) from 0-100 psi in about 30 seconds with the engine at 2000 rpm.
then i have an electric over air solenoid on the air horn, and the electric curcuit only controls which horn gets the juice when i hit the button.
my picture gallery
my picture gallery
- bleedfordblue
