chop top has begun for "el diablo" update11-7-14
- customcrewcab
re: chop top has begun for "el diablo" update 7-09
ok wheres this windshiled already hope he not charging you by the hour. took you less time to chop it the get this windshield in
- marz68
Re: re: chop top has begun for "el diablo" update
The guy took the measurements and will start making it once I give him some money that's were the problem is "NO MONEY"customcrewcab wrote:ok wheres this windshiled already hope he not charging you by the hour. took you less time to chop it the get this windshield in
- customcrewcab
heard that i am broke too. does he have to cut a stock windshield or somthing different like ? i have a broke car and truck and acouple that need to be finshed. lucky i have a car pool for work. i have money to fix the truck and car but hope they heal on there own.
- marz68
my friend at the shop told me that the glass guy was going to supply everything new so i really don't have an idea of what it take to do the work.customcrewcab wrote:heard that i am broke too. does he have to cut a stock windshield or somthing different like ? i have a broke car and truck and acouple that need to be finshed. lucky i have a car pool for work. i have money to fix the truck and car but hope they heal on there own.
That would be cool if cars could heal them selves
- pat67shorty
Damn that 3" chop just looks right. You have changed my mind on the looks of a bump being slammed or being chopped. Kudos.
'67 SWB, 1970 car 390, Edelbrock Streetmaster intake, MSD 6AL, 780 Holley, Hedman headers, 2.5 duals, 3.54 D44 L/S, C6.
- customcrewcab
- marz68
- customcrewcab
can't chop mine until i know the window fits
- marz68
- customcrewcab
well whats the pillar sitting back? 1 inch? so the bottom sitting in the same spot the the top is one inch out of wack. so how the glass being trim is what i want to know. is he triming the sides too? just trying to figure out what keeping the bottom from pushing out when its laid back there be 1/2 top and bottom
- customcrewcab
he trinming the top on bottom of the window
- marz68
- customcrewcab
well if he trims that 1/2 extra on the top and bottom down to 1/4 on both ends it prob get hidden in the rubber. just wondering
- marz68
im curios to see what he doescustomcrewcab wrote:well if he trims that 1/2 extra on the top and bottom down to 1/4 on both ends it prob get hidden in the rubber. just wondering
- marz68
