I know this type of question os answered very often on here, but please forgive me of asking it again.
I am interested in upgrading to larger tires on my stock '72 F-100 LWB 2wd. I have the original 15 inch rims and plan to keep on using them.
What is a good size and or brand of tire that you'd recommend for a 15" rim? I want to go up to at least 235/75/15 from the 215/75/15s I have on it now, maybe even bigger. Another question is at what size tire do you need to start lifting your truck to allow it to fit/clear the wheel well, especially when turning?
Any input, opinions, feedback, or advice would be greatly appreciated. Thank you.
Another Tire/Wheel Question
- TexasTruck72
Jack
1943 Ford GPW Jeep(sold)
1972 F-100 Custom
1976 F-150 Explorer
1996 F-150 Eddie Bauer ed.
1972 F-100 Custom
1976 F-150 Explorer
- one_am
Re: Another Tire/Wheel Question
What look are you going for? how wide is your rim?
69 F100 custom cab swb 460 c6 9 code rear axle (project).
bjde0b wrote:I jacked a sway bar off...
- TexasTruck72
I trying to improve my bump's traction, especially on dirt roads. Also trying to achieve a smoother ride on & off road. My rims are stock 15" rims and I don't quite know the diameter, but I'd have to guess it's somewhere around 6".
Jack
1972 F-100 Custom
1976 F-150 Explorer
1972 F-100 Custom
1976 F-150 Explorer
- BobbyFord
BFG All Terrain T/A's are a good tire choice. They work well on and off road and are also good in the rain. You'll probably want to increase the rim width to 8". Depending on your spring sag you can probably go with a 30" or 31" tire.
- Caseys71
BobbyFord wrote:BFG All Terrain T/A's are a good tire choice. They work well on and off road and are also good in the rain. You'll probably want to increase the rim width to 8". Depending on your spring sag you can probably go with a 30" or 31" tire.
Casey
