trucker/ camper mirrors
jeffery2304
Post by jeffery2304 »
feeling this out..have ah set of trucker style mirrors maybe this isnt what they call them i dont know... dont think a better used pair could be found. could someone tell me what i could expect to get for these.... these were on my 60 f100 that came with a box camper. thanks.!
HIO Silver
Re: trucker/ camper mirrors
Post by HIO Silver »
They're likely two-legged "Jr. Western Mirrors" or three-legged "Western Mirrors".
A perfect, NOS set is $250 and up. An excellent set of Westerns is $150 and Juniors are about $100. An average set is about $100 and $75, respectively.
The T-bolts on the upper door mount are hard to find. Same with the hard plastic "gasket" on the lower mount. A buyer would appreciate having them whatever condition they might be in.
jzjames
Post by jzjames »
HIO Silver wrote: hard plastic "gasket" .
I guess I'm Hijacking Fordification again, but
what is this??
mrollings53
Post by mrollings53 »
It's the seal underneath the mounting foot of the mirror. It was meant to protect the paint, and keep out water. I'll post a pic later if I can remember.
You can see it here.
jeffery2304
http://www.ebay.com/itm/1970s-ford-jr-w ... 1355798158 these look like mine..jr,style. mine will be up for sale soon..thanks HIO
fireguywtc
Post by fireguywtc »
I believe people are incorrectly identifying what makes a mirror a west coast or a west coast jr. It is my understand that a west coast mirror is the larger 17" mirror commonly used on larger trucks. The west coast jr. is a 12 long mirror used on pickups. The type of mount it sits in doesn't matter.
Bill
colnago
Post by colnago »
Interesting. I thought the Jr. was the two-legged mount, and the Sr. was the three-legged mount, but the mirrors themselves were the same. Didn't know there was a larger mirror. Do you have any pics you could post?
On edit, if the Jr. and Sr. are designations for the mirrors (which makes sense), is there a designation for the mounts?
Joseph
HIO Silver
fireguywtc wrote:I believe people are incorrectly identifying what makes a mirror a west coast or a west coast jr. It is my understand that a west coast mirror is the larger 17" mirror commonly used on larger trucks. The west coast jr. is a 12 long mirror used on pickups. The type of mount it sits in doesn't matter.
Nope. The difference was the third "steady" rest arm and the Juniors (two-legged) had swing locks. The heads are the same.
motzingg
Post by motzingg »
what about a california mini?
ha, had a chevy guy trying to tell me thats what they were called... i think its a stepside/flareside kinda thing?
I've definitely seen large and small 2 post mirrors in the junkyard but who knows if they were OE or aftermarket.
JC whitney has the re-pop style ones for $30, who knows if they are any good or not... i think probably good enough for my truck... 100 bucks for a set of crummy old mirrors is gonzo.
Ranchero50
Post by Ranchero50 »
I think the 2 post ones would look more correct on a F100 or F250 while the 3 legged ones are for the F350's with dual rear wheels.
For a '60 F100 I'm pretty sure they were added on after it left the dealers lot.
mrollings53
Both my '69 F250 and '71 F100 have the 3 leg mirrors stock.
NM5K
Post by NM5K »
Maybe so.. I had always called the ones with a outside bar parallel to the mirrors a west coast mirror. Same as the usual semi truck.
My 68 had the three legged mirrors that were fairly big, but I didn't consider them to be west coast mirrors.. Just over sized
pickup or delivery truck/van type mirrors.
I didn't like them as they were like small barn doors on each side of the truck, and I felt they added too much wind resistance,
which also added more noise. A friend of mine had a pair of 1987 Ford truck mirrors with the single curved bar look.
The mirror fronts are more aerodynamic and have curved fronts so to speak. I like them much better, and still are using
those. They are a good bit quieter at speed, which tells me the resistance should be down a bit. Saves a tad bit of gas maybe..
One thing I like about these is that you can swing them inwards to get them out of the way if needed. Might also save some
damage if you hit something with one. :oops:
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
jeffery2304
HIO Silver wrote:They're likely two-legged "Jr. Western Mirrors" or three-legged "Western Mirrors".
can i get a desciption of the t bolt u mentioned or a pic please..my mirrors measure 10'' by 6" single stud mount both ends. thanks for the help,
jeffery2304
great lookn truck..very cool!!
Mancar1
Post by Mancar1 »
I have had both styles and from what I have noticed is that the difference in in the mounts. Of course I did not have them at the same time so as far as I know there could be a little difference in mirror size.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
