Has anyone swapped F250 rear springs for F100 springs on a 3/4 ton to smooth up the ride? IF so, did you have any issues?
I want to keep the floating D60 rearend in my F250 but would like to soften the ride a bit. I don't plan to load it to the point that the F250 springs are necessary.
The other option would be to remove half the F250 springs.
Just looking for experiences from what others have done and hopefully shorten my learning curve.
Thanks
F250 to F100 rear spring swap
- snake
"It's better to be hated for who you are than loved for who you're not....." Van Zant
"If you can't say something good then there's nothing good to say...." Big and Rich
- Dirty Offio
Re: F250 to F100 rear spring swap
If your perches are the same width (width of springs) and distance apart (length of springs) it should be plug and play. I THINK (as in not positive) that the 1/2 ton springs are wider than the 3/4 ton. Easy to find out with tape measure. Just an fyi, your ride height may change when you do this...you might need a small lift block to keep your truck at the same stance.
Cheers.
Offio
Cheers.
Offio
When in doubt, hit the gas. It may not be the right answer, but at least it ends the suspense!!
The only substitute for Cubic Inches, is Cubic Money!
1967 F-100 swb "Varmit"
1968 F-250 4dr lwb "Beast"
1976 F-350 drw 460
1977 Club Wagon
1986 F-250 lwb
1976 F-350 drw 460
1977 Club Wagon
1986 F-250 lwb
- snake
I think the spring bushing part number is the same for both so i concluded from that that the springs are the same width. But I already have both so putting a tape measure on them will confirm. I don't mind that it will sit a little lower too.
- guhfluh
The spring eye bolts are larger on F250 springs. You can change the F100 bushings to larger F250 bushings or drill them out. I removed leaves from my F250 pack and now have a combination of F100 and F250 springs for the ride and height I want.
'96 Dodge Ram ECLB CTD
'05 Infinity G35 Sedan
- snake
Ah - yes, i see now that the bushings are different. Must have read something wrong before.
I'd be interested in hearing details on your F250/F100 spring combo setup.
- guhfluh
If you aren't lowering it any, a F100 pack might be better. Right now I have 4 of the 8 original F250 leaves, the bottom overload is upside down and one of the middle leaves is a F100 added in, for 5 total. It's pretty soft, but I'm still playing with it. I have rear lowering shackles and moved the front hanger up some too, to lower it about 4-5 total with the springs. Just taking out the leaves lowered it quite a bit. The top overload had to be removed, but the frame pads could stay, if you have that setup.
