Can a bad power brake booster cause engine problems?
Pat Crash
Post by Pat Crash »
I read somewhere that a bad power brake booster can cause vacuum leaks which can affect engine performance. Mine sometimes makes a hissing noise when stepping on the brake pedal. Is there any merit to this?
1971 Ford F100 Ranger XLT Long Bed — 360 with C6 Automatic — 9" with 3.00 Gear Ratio
1972hiboy
Re: Can a bad power brake booster cause engine problems?
Post by 1972hiboy »
absolutley, If the diaphram inside the booster ruptures. instant vacuum leak to your intake manifold. thus causing engine performance issues like running lean, induction backfire's. etc etc. if yours is hissing then its probable you have a defective booster.
Rich
Dont eat yellow snow.....
Pat Crash
Post by Pat Crash »
1972hiboy wrote:absolutley, If the diaphram inside the booster ruptures. instant vacuum leak to your intake manifold. thus causing engine performance issues like running lean, induction backfire's. etc etc. if yours is hissing then its probable you have a defective booster.
Thanks for the reply! :D I guess that repair is now a priority.
