1969 highboy boxwood green
hfdco4
Re: 1969 highboy boxwood green
Post by hfdco4 »
Truck looks amazing. You have done a great job on it. :thup: :clap:
:fr: FE390PC
1guydude
Post by 1guydude »
Well? U just cruzin enjoying ur truck?
-d
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
Lone Ranger
Post by Lone Ranger »
1guydude wrote:Well? U just cruzin enjoying ur truck?
-d
Haha yup! I've done only minor things to it lately. Until it left me stranded. Something is going on with the charging system again. I should probably do the 3G swap and be done with the problems. also just picked up a carb kit today for it since it needs it bad. It's kinda been on the back burner of late, way to many other projects going on. I do still get to at least look at it :lol:
Kyle
Manny
Post by Manny »
-d
You will not regret the 3g swap. Got 3 trucks running them. 2 to go.
www.dbelectrical.com look for 93' taurus 3.0 liter. 130 amps
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
Lone Ranger
Thanks for the link Manny. The 3G swap doesn't seem to tough. Any advice or things to watch for when I go for it?
Rebuilt the carb the other day feels like I have way more gas pedal now.
Truck has been running hot lately so I decided to swap the water pump. I figured it's cheaper than a radiator and it might fix my problem. Well got the pump home painted it Ford blue and then found out it didn't fit. Oops. Took it back to napa and swapped it with the right one(somebody gets a free paint job :lol: ). I was glad they took it back at least. painted up all the pieces.
Then threw it back together.
Also changed the alternator with another I had laying around hoping it can get me by for now. The water pump helped but didn't fix my over heating problem. Guess I'll just have to get a radiator, bummer.
Kyle
Lone Ranger
Well I made a scrap run today at the local junkyard and decided to scout around for a radiator while I was there. I didn't find a radiator but did find an alternator from a late 90's supercharged mustang.
Once it was on the bench I decided to wire brush it off and decided a wire wheel would be faster. It quickly made it shiney and put a bit of paint on it where it was black.
Once I get the rest of the stuff I need my truck is getting the 3G swap, no more charging problems. Then I can clean up all the wires in the engine bay.
Kyle
1guydude
Post by 1guydude »
Im prob gonna end up doing the same update man on mine. Also i changed the water pump by or at the shop. Said i would need a new radiator soon especially with the hot weather. Mine was smoking a lil when it broke down yesterday. Ive been looking at the 3 row aluminum ones on ebay...
Gonna ask on FB and see if anyones used one.
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Lone Ranger
I've been looking at radiators too, looks like around 150 bucks that I don't really want to spend right now. Stuff adds up quick. All the money from selling my last truck went into the wife's car so I'm trying to do things low budget for now.
Kyle
SeapineF37
Post by SeapineF37 »
Nice! Truck looks great and enjoying watching the upgrades. That alt turned out sweeet! Just had to replace the old radiator in mine. Went with a champion alum from jegs. Good fit and was only $230...
1972 F350 seapine green cab/chassis drw
only one who has learned much can fully appreciate his own ignorance. louis l'amour
Lone Ranger
Thanks guys. I've been pretty busy but still find a little time to tinker with the truck. I installed a maglight/weapon above the window.
Also got a new distributor cap and rotor. The new rotor made it run a lot better but the new cap made it run awful( it would barely run) and there is no way to make adjustments, so I put my old corroded cap back on and it ran great :hmm: also tightened all my vacuum lines up and really noticed a difference with that runs great now again! Still haven't gotten to the 3G swap yet, and I want to upgrade to eloctronic ignition too. Here's a pick of the new fuel pump top end.
Kyle
hfdco4
Post by hfdco4 »
Looks great.
:fr: FE390PC
Manny
Post by Manny »
Looks good as always. I have never seen a angled oil filter adapter on a 300 six. Was that on there when you got it?
Lone Ranger
Manny wrote:Looks good as always. I have never seen a angled oil filter adapter on a 300 six. Was that on there when you got it?
Yeah I swapped out the filter but figured it was a stock setup. Do they usually stick out sideways?
Truck has been running great! Just ordered a mega fuse for the 3G swap. Got a few days off this weekend so hoping I can work on it.
With the 3G swap does the voltage regulator get deleted?
Kyle
Manny
Post by Manny »
Yep and yep. Normally 300's stick out straight from the block. But hey always something new to see around old fords. As for the 3g swap yes you delete the voltage regulator. Just google the 3g wiring diagram. tons of them. The 3g should take your yellow and green wire from the regulator. Then the white wire loops from the alternator connector to the field windings connection. Think you have that connector right??? :thup:
Manny
Post by Manny »
Just looked again yes the yellow is the voltage sensing. the green and red stripped is key on energize you can pull it from the old voltage regulator as you aim it at the scrap can..
